Control channel selector menu outside screen
Pierre Fagrell 7 years ago in IQANsimulate • updated by Gustav Widén (System support) 7 years ago • 3
In most situations the menu for selecting a control channel is aligned outside the screen, making it impossible to select all channels on a regular 1080p monitor.
If I have the simulator at the bottom half of a 4k monitor or fullscreen on a regular monitor it aligns incorrectly.
Image 1683
Image 1684
If I have the simulator fullscreen or aligned to the top of a 4k monitor it works fine.
Image 1685
This problem still exists in IQANdesign 6.01 if you have many levels of nested function groups.
The GUI does not realize the total amount of channels before rendering so the menu appears too close to bottom of the screen.
Functiongroup.Subfunction.subfunction.subfunction.channels
As a fallback, perhaps it would be a good idea with a scroll arrow in case a menu ever reaches the end of screen?
