Declined
The possibility to configure the G2 modem via a master module using USB/Ethernet
Huddig Daniel 12 years ago
in IQANrun
updated by Ulrik Zakariasson (Software development) 11 years ago •
2
It is only possible via CAN-connection today and all of our service dealers are using USB.
Since Ethernet probably will be the preferred conection in the future, configuring the modem via the master would be a good solution going forward aswell.
This was reviewed yesterday by our change control board. I'm sorry to disappoint you, but this feature was declined. The reason being that the new IQAN-G3 will not need configuration (if the internal SIM card is used).
