Qcode Component search
Andy Pauly 7 years ago in IQANdesign • 0
Hello
I find very often that the right Component is not found in Qcode text search.
For example: locking for the 1st. Act ..  channel
1    ->
Image 1713
1s   ->
Image 1714
No component is found starting with a 1s...
Even the channel exists:
Image 1715
This happen quite often with a combination of 1st..  2nd.., 3rd...,  4th..., CDD#3..   etc.
It is very hard to find the right channel without the text-limitation-search feature.
I hope that you can fix this issue otherwise I have to understand the rules behind the text-find-system so that I can use the right channels text to avoid this problem.
Regards
Andy Pauly
