Dual Axis bubble level
Zach Dockter 11 years ago in IQANdesign • updated by Thomas Moberg (System support) 11 years ago • 1
Could a grid field be created for the display modules to dynamically move an image along an X-Y grid dependent on two variables?
i.e. What I am trying to create is a virtual dual axis bubble level similar to the one on most smart phones.
Hello Zach.
You can not make a image move around on the display.
But you can make so that it looks like a square is moving around on the screen.
If you use two bar graphs that meets vertically and two that meets horizontally and set the background color of the bars to be transparent, you can offset the range and get a square in the center that you can move around by controlling the bar graphs.
Then you can add a grid over those to make your graph.
I made a small example of how this can be done here
Example.ids3
