Memorizing Channel Reset Value Disabled
Chris Litwin 7 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 3
In IQANDesign 6.0 using a memorizing channel with an input channel of State value type disables the reset value. This makes sense. However, if you change the input to a different type the reset value does not get enabled again. The only way to bring it back is to close the project and reopen.
Satisfaction mark by Chris Litwin 7 years ago
