The DM2 support on IQAN 6
J C. Crow 7 years ago in IQANdesign updated by Gustav Widén (System support) 7 years ago 6
The DM2 support does not seem to be working on IQAN Design 6. It always comes back with "No response on DM2 request".
Does the CAN node you are sending the DM2 request to support DM2 ?
Not all engine controllers support DM2, some only support DM1.
The DM2 support is enabled.
The engine does support DM2. We are using it successfully on our production program which is IQAN 4.
Any JFIN:s in the application with PGN:s that could come in and override the built-in DM2 function ?
PGN 59392 (ACKM) , PGN 60160 (TP.DT) or PGN 60416 (TP.CM)
I reproduced the issue on version 6.01, seems as if RTS/CTS is failing somehow.
Investigating.
