Memorizing Low and High on a voltage input
M S 7 years ago in IQANdesign • updated 7 years ago • 2
I have a voltage input that fluctuates from around 1.3 volts to 3.8 voltes one time each second.(Angle Sensor)
Is there any way to have a memory channel record the low voltage every cycle?
I have had this requirement too across a few different OEM applications. I  would suggest setting up a MR channel that looks at the current value of said the MR channel, and overwrites itself if the value of the VIN you want to datalog is > or < than the stored value (depending on whether you want to capture the  highest or lowest value).  Trust this helps a little. Nick.
Thank you Nick that does help.
