Not a bug
Interactive message channel with Help on MD3
AxelC 11 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 11 years ago • 2
If you create an interactive message channel using a right button and an help text,
on the MD3 the right button become help button.
It is ok if you know it but IQAN should disable the right button config if help text is there, to avoid confusing the developer.
I agree that it could be a bit confusing, but this one would actually be quite tricky to change. The property would have to be disabled due to a selection of another property, and also the master module type. If there is an MD4 somewhere in the system, the rigth button and the help text will be shown.
For now we have solved this by writing about it in the hint for the properies 'Right button' and 'Help'
