It would be nice if the "Go Up" worked when inside a Finite State Machine
Glenn 7 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 2
It would be nice if the "Go Up" worked when inside a Finite State Machine.  Right now, I use backspace all the time to navigate up.  However, when inside a Finite State Machine, this does not work.  When you hit backspace, it highlights the "Name" field.  Then if you accidentally hit backspace again, it deletes the name field text.
Great, works well, thanks!
Satisfaction mark by Glenn 7 years ago
