Project ID Change and Password Issues
skh69nova 7 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 1
I started a project from an old project and did a lot of work.  When it came time to deploy i changed the project ID.
I can no longer login with the password, any thoughts?
When you choose to save the full access password or limited access password in IQANdesign/IQANrun, it ends up in the password database.
For the password database in IQANdesign and IQANrun to work, the Project ID must match.
To open the project file after changing the Project ID, you must enter the clear-text password again.
