Dither on MC43?
Kevin 7 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 1
Many years ago we used to have dither control on COUT's, but this was removed a while back i believe. We have an application that requires some dither control on some current outputs from an MC43, can anyone suggest a good way of integrating it? I cant see anything that points towards dither frequency (only PWM frequency) in the module configuration settings?
After adding the COUT to the MC4x/XC4x module, you find the property for the PWM frequency on the pin in the block diagram.
The PWM frequency will be your dither frequency.
Also see question about dither amplitude here:
https://forum.iqan.se/communities/1/topics/56-ajdusting-dither-amplitude
