DM1 Priority Order
Carl 7 years ago in IQANdesign • 0
We think it would be a great idea if we select the order that DM1's are transmitted as required. So in the DM1 page, you could select the order say 1 - 10. Then as the DM1's become active, they move to the indicated priority position.
This allows us to show an operator the most important DM1's first. Like if there is a low voltage issue that causes many issues and many DM1's that are not actually the issue so we can promote the low voltage one to the front.
