Bluetooth connection
Paulo Negrete 7 years ago in IQANrun • updated by Carl 6 years ago • 5
Please, anyone know how to do a Bluetooth connection between adapter IQAN-G11 and a Windows PC with IQANRun installed ?
Hi Guys,
any news on this? We use IQAN Run using scripts to program machines but have to hardwire to the machines. Boing it via G11 would be great"!
There is a feature request for it here, https://forum.iqan.se/en/communities/1/topics/505-iqanrun-bluetooth-connectivity
We've looked some more at this recently but need to improve stability before we can put in in a release.
Another option, if you are using a module with Ethernet communication capability such as a MD4-x or MC42 or MC43, is to connect a wireless router and use the WIFI signal.  I have used this a few times and it seems to be solid.
hi ya, the controllers are buried inside the machines and doing around 30 ish machines a day, not something we can fit / unfit on each. We currently have a diagnostic socket we plug a G11 in for diagnostics, be good if we could do the same with IQANRun.
