Show send/get options dialog for IQANrun
Pawel Pekala 7 years ago in IQANscript • updated by Gustav Widén (System support) 7 years ago • 1
When default FP value change or needs to be corrected during program development, IQAN design allows you to overwrite original defaults when sending new program file. This would be a helpful option to have in IQAN Run.
Image 1985
Image 1983
Image 1986
Using IQANscript, you can create a small script that does this.
Login
Script page with checkboxes
Send project with Reset to application default controlled by the input from the checkboxes.
