two camera display
BLC 6 years ago in IQANdesign • updated by andyr 6 years ago • 2
Can you display 2 cameras on one MD4 at the same time, like a split screen?
Yes, just use two video controls and select one SV camera for each one.
You may need to crop the dimensions when you have the video controls side by side.
we have successfully used four iqan sv camera feeds in one of our previous projects. split/full screens can be programmed via logic. You need to use an ethernet switch or similar- a good robust one we used was by Murrelectonik.
