rotate images
Carl 7 years ago in IQANdesign • updated by Edward Polzin 7 years ago • 1
Hi all,
Is there a way we could rotate images on an MD4 from the center of the image. The current setting rotates from top left?
In the image properties, under the Rotate property, there should be an X and Y position.  The X and Y position are the point within the image of rotation.  By default, this is 0, 0.
