Replace Channel List Cutoff
Chris Litwin 7 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 4
I'm running IQANDesign 6.02.10 and when using the replace channel function the list gets cutoff at the bottom of the screen with no arrow to move down.
Image 2072
Satisfaction mark by Chris Litwin 6 years ago
I have the same problem with iQAN 6.04.
If the channel you right click is in the center of the screen it works fine.
If it happens to be at the top of the screen the menu goes outside the top of the screen and vice versa if the channel is at the bottom.
Started
In 6.05 there will be arrows to scroll through the list if it is too long to fit.
Solved in 6.05
51487Replace channel list cutoff
Added support for scrolling in the replace channel context menu.
