Parameter Adjust Group from Application Logic
S K 7 years ago in IQANdesign • updated 7 years ago • 4
It would be nice to be able to see what adjust group a certain parameter channel is part of directly from within the application logic.
You can select the parameter and use the component navigator (ctrl+j) to find the adjust group that it resides in.
Maybe I'm missing this but even with the component selector and jumping to the adjust items page, I dont see which adjust group it belongs to. It shows which function group but not adjust group.
It would be nice to be able to see which adjust group a parameter belongs to directly in the application logic,  maybe have it as a property.
Please see example using the component navigator below:
I selected my adjust item, in this case, it's a Memorizing Channel.  Crtl+J to open the Component Navigator.  I click on the highlighted adjustable item:
Which brings up this view:
Lighting Force is the Adjust Group.
I see. Thank you Edward.
Going back to the original idea, it would still be nice to see this directly from the Application Logic rather then having to jump around for every parameter.
