MD4 multiple J1939 SA addresses
Jacob Mathai 7 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 3
Is it possible for one MD4 to have multiple J1939 SA addresses? For example one SA (SA=0 or 1) to communicate to another MD4( SA=39) and another SA (SA=49) to communicate to engine and transmission?
Answer
Answer
Hi Jacob, you can only set a master module to have one source address, but you can set J1939 output channels to use a different source address for sending the message.  As an example, some engines use a specific source address that the TSC1 message must be sent from.  In the TSC1 channel you can specify the sending source address.
Answer
Thanks a lot Kerry. I'll try that.
