Gradient on simple line
Nicolas Soret 6 years ago in IQANdesign updated by Gustav Widén (System support) 5 years ago 2
Hi everyone,
When I put a simple line on a display page, if I choose a gradient for color, in Iqan Design I see correctly the gradient but when I simulate, only one color on my line.
How can I use it? I try with linear bar but the result is not like I want.
Thank you everybody and Byebye
I had a look at it, and I think there is a problem with how gradients are handled on vertical lines. When the gradient direction is set to default, the MD4 will draw the gradient along the x-axis of the vertical line.
But even when manually setting the gradient to another direction, I still didn't get it to work on a vertical line control.
Check out how it works in 6.05, consistency with the gradients has been improved in this version.
