Decoding CAN Data from another system
Kevin 6 years ago in IQANanalyze • updated by Gustav Widén (System support) 6 years ago • 5
Can anyone help me get this information into my system? This is the information i can see in IQAN Analyse, can anyone tell me how to 'decode' this and extract the information inside a module inside IQAN Design please?
Image 2095
Specifically its the highlighted bits of information i need insed my program.
Answer
Answer
It doesn't look like J1939, it looks like 11 bit identifiers, and all the ID:s look like the CANopen defaults.
IQANanalyze, switch decoder from J1939 to either Generic or CANopen.
The easiest way would be to use the CAN database in IQANdesign and add the TSC1 JFIN.
You can find the CAN database under the tools menu.
Then you can search for the TSC1 and add it.
The control system is not an engine, will this still work?
i have added it, but all i get is this in IQAN Design:
The data i wish to read is the highlighted one in the image below, is there anything i am doing wrong?
Answer
