+6
G11 option for connectivity with IQAN Analyze
C. Harp 9 years ago in IQANanalyze • 0
I would like to see the G11 module added as a device to connect with via internet through IQAN ANALYZE similar to how RUN and DESIGN currently have the option. This would be a very useful tool for diagnosing issues in the field for customers that have the G11 but do not have a CAN sniffer available.
The G11 has been a very useful tool for me and i would like to see its capabilities expanded.
+4
Ethernet CAN Analyze
Joe 3 years ago in IQANanalyze • 0
A very useful tool would be to take advantage of the ethernet connection to a master module as a method of bridging to the IQAN Analyze tool. A way to look at all the CAN traffic by selecting a specific bus to monitor would be much easier than connecting to the bus via a CAN adapter.
Add import of dbc file into IQANanalyze for custom decoder into engineering units
Paul Summers 5 years ago in IQANanalyze • 0
This would allow for custom decoders and increase usability for people that are not as familiar with hex for diagnostics
IQANanalyze menus and text is very small
Pierre Fagrell 5 years ago in IQANanalyze • updated by Michael Carlyle 5 years ago • 1
When using a modern monitor the menus and text is very small in analyze compared to design, almost unreadable without magnifying glass.
Here is a picture with them side by side for comparison:
Image 3034
Is there any way to change the scaling?
Windows 11 Pro
Resolution 3840x2160
Scale 150%
Add additional "Save As" formats
Paul Summers 5 years ago in IQANanalyze • updated by Pawel Pekala 5 years ago • 1
It would be very helpful to add additional export file formats such as .blf or .mdf to allow for a capture to be logged by a field tech or customer that already has IQANanalyze, which then can be imported into more powerful software for detailed review.
iqan analyze screen zoom
Steve Liljestrand 11 months ago in IQANanalyze • updated by Matt 11 months ago • 1
Has anyone experienced an issue in IQAN Analyze where the screen font size is extremely small? If so, is there way to correct it? It's as if I zoomed out to 10% but there is no zoom feature that I can find.
IQANanalyze alternatives
mgarner 1 year ago in IQANanalyze • updated by Matt 1 year ago • 2
Is functionality being added to another software to fill this gap now that IQANanalyze is being depreciated?
Add ability to import dbc file to highlight logged PGNs which are not in the dbc file.
Matt 1 year ago in IQANanalyze • 0
I would like the ability to import a DBC file (exported from design) into iQANanalyze so that I can easily see what PGNs are actually on the bus, but not accounted for in my design program.
Issue jumping to specific PNG when statistical view is sorted by PGN value
Matt 2 years ago in IQANanalyze • updated 2 years ago • 1
In iQANanalyze 6.00 when I sort the statistical view by PGN value I am unable to jump to the correct item in the frame view window.
I sort by PGN and double click a specific PGN item in the statistical view, the program highlights a frame in the frame viewer that has a different PGN value. I suspect that it is jumping to the item with a PGN value that would match the PGN of the row in the statistical viewer before I reordered the list by PGN.
IQANanalyze Not Populating all ID's
ksilovich 3 years ago in IQANanalyze • updated by Gustav Widén (System support) 3 years ago • 5
In the master list of CAN ID's there are alot of them missing, but if you go to filter a message you will find it. And if you select only that message it will appear then.
Ex 1218 does not exist when you show all ID's, but if I filter 1218 only then I can get the data.
When you are trying to reverse engineer a CAN bus and need to quickly know all ID's that are being broadcasted on the bus, this is a Major issue.  Spent hours wondering why my CAN router was not working, Its because I am missing ID's that I did not know existed.
