Issue with channel order
Glenn 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 3
Issue with channel order, ver 6.02
Steps to recreate problem:
1) Create 3 signals
2) Set "Internal digital 1" as output
2) Set "Internal digital 3" as output
3) Set "Internal digital 2" as output
Then compare the Calculation Order to the Function Group order.
To resolve this issue, you need to go make a change to the order, then change it back.  Then all will be correct.
Image 2100
Image 2101
Image 2102
I think IQANdesign has always worked like this, at least going back to version 2.x.
When you first change the scope of a channels to Function Group Output, this new FGO will be added to the bottom of the list of function group outputs.
When you later change calculation order within the function group, the list of function group outputs are sorted in calculation order.
That's fine, it's not a big issue.  It just behaves in a non-intuitive way.  In all other cases, the calculation order reflects/determines the order of the FGO's.
