Built in TSC1 Descriptions
Chris Litwin 6 years ago in IQANdesign • updated by mdonaldson 6 years ago • 2
I am having a problem creating and using a JFOUT for TSC1. The engine is stumbling when I use the JFOUT. I assume one of my JPOUTs has an incorrect value. The built in IQAN TSC1 channel works correctly with no engine stumble. Could you describe what the values are for the built in TSC1 so I can match my JFOUT to the built in TSC1?
Image 2170
Override Control Mode 2 bits = 1
Speed Control Conditions 2 bits = 3
Control Purpose 5 bits = 2
Requested Speed 2 Bytes = Your Request
Transmission Rate 3 bits = 5
OCM Priority 2 bits = 3
Counter 4 bits = 15
Checksum 4bits = 15
