Propagated function group outputs disappears
Pierre Fagrell 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 6
I have had two different applications where a previously propagated output stops being propagated.
Usually after adding function group inputs or outputs in other places.
Sometimes it keeps working and no problem is shown in the project check until later.
I now have one example that is running fine, a propagated output is used in a function but it is not shown as propagated in the origin.
Image 2181
Image 2182
Satisfaction mark by Pierre Fagrell 6 years ago
I faced the same problem. It seemed to me that this happens when group calculation order changes (but I'm not sure).
Every time I have to manually restore all references...
IQANdesign 6.02.10.5706.
External references do not disappear if after "outer" FG changes the propagation is manually restored (otherwise, when moving to a higher level, all references will disappear). Sorry for bad English...
Thanks. I managed to reproduce it, added another FGO to the level the channel was propagated to, and changed calculation order.
