XA2 and XC43 on same bus
mgoutier 6 years ago in IQANdesign • updated 6 years ago • 2
can I put an XA2 and an XC43 on the same bus? The only reason I ask is because the XC adds the HS Exp bus.
You can (in 6.03), the drawback will be that the HS Expansion bus will have to be limited to classic CAN 250 kbps. This means you won't have the same benefit in bus utilization as you could have with only XC4x expansions.
