Undefined ChannelName in Array channel when used in Externals
EmilFernlund 6 years ago in IQANdesign updated by Gustav Widén (System support) 6 years ago 1
The ChannelName in the Array Channel is correct in the external function.
When imported as an external function the ChannelName is changed to "Undefined" in the Qcode.
When simulating, as seen in the figure, the Array channel returns the correct value.
Using IQANdesign 6.01
Image 2193
Satisfaction mark by EmilFernlund 6 years ago
In previous versions, there was a problem with copying arrays that were referencing themselves, the copy worked until the Qcode expression was checked.
Solved in version 6.02 (the version also introduce a new keyword, This)
