solution library
Geoffrey 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 1
Where do I get the solution library to actually add the solutions that are shown in tools>>Library Manager>>Solution Library?
To add something from the solutions library to your application, select the solutions tab under the Add button in the application view:
The solutions library get added when you install IQANdesign, but you can also add a new categories and project to the library
These show up along the the solutions that come with the installation:
