IQANdesign 6.04
Gustav Widén (System support) 6 years ago in IQANdesign • updated 6 years ago • 2
Main updates
MD4: Solved problem in MD4 flash memory error correction
In rare cases, the error correction for the MD4 could fail. If this happened the application and/or firmware had to be sent to the module again to make it operational.
Status measure improvement
Reduced height of status measurement in IQANdesign/IQANrun by only showing lines with different statuses.
    For more details, see IQANdesign and IQANrun release notes
    http://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%206/ReleaseNotes6.04.4.htm
    http://divapps.parker.com/divapps/iqan/Downloads/IQANrun%206/ReleaseNotes6.04.2.htm
    New release version of IQANdesign 6.04 released, containing PC fixes (No change in firmware).
    http://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%206/ReleaseNotes6.04.5.htm
    There is a new release version of IQANdesign available
    IQANdesign 6.04.9.
    XC4 firmware update to solve an issue with too sensitive error detection
    Master modules also updated to solve an issue from 6.03, where get application / get clone was slow over Ethernet.
    See release notes:
    http://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%206/ReleaseNotes6.04.9.htm
