MD4 Flash memory Max size displayed in Project statistics
Omer Gagne 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 1
I saw in specs that MD4 contains 2GB of Flash memory.
When I load a project with IQAN 5.03 and I look under Project Statistics, it is showing this:
Image 2282
Did I make a mistake somewhere in the settings of my project?
Is IQANdesign limited to 1000MB max size?
The limit 1000 MB for total stored size is for the parts you create and add yourself, the application logic, images, pdf:s, fonts and language translations. In practice, you will never get close to to this limit.
The total physical size of 2 GB includes this, but also reserved areas for other parts, like the firmwares.
