Script hangs on switch-else despite switch-case evaluated to true
Johan Palm 6 years ago in IQANscript updated by Gustav Widén (System support) 6 years ago 5
The attached script was created in IQANscript 5.07.1.4875 and tested in IQANrun 5.07.1.5363 as well as IQANrun 6.04.2.5572.
Creating the script in IQANscript 6.04.1.5081 makes no difference.
The script hangs on a blank page in IQANrun after either switch-case has evaluated to true and it's not possible to continue execution.
Image 2350
Stuck.issx
Satisfaction mark by Johan Palm 5 years ago
Hmm.. I've never put an Else at the end of a switch-case, but when I test now it seems IQANscript allows that combination.
I assume the intent is that it should work like the default.
Looks like a bug in IQANscript or IQANrun.
Thanks for your reply. Yes, that's how I understand it's supposed to work according to the documentation.
Started
Got confirmation that the bug is in IQANrun.
You are absolutely right, it is supposed to use the Else as default.
Will be fixed in IQANrun 6.05.
