Get parameter on SP changes type from Integer to State after first run
Johan Palm 6 years ago in IQANscript updated by Gustav Widén (System support) 5 years ago 2
The value type of Get parameter is initially Integer, but after successful execution, the value type changes to State (see bottom right corner) and Script file Check throws a Value type mismatch error for Set variable since it's not allowed to assign State values to Integer script variables.
This was tested with IQANrun 6.04.2.5572, IQANscript 6.04.1.5081, IQANdesign 6.04.5.5888, and IQANsimulate 6.04.1.5081.
Initially:
Image 2351
After execution:
Image 2352
The IQANdesign project used contains only an adjustable empty State parameter channel (SP).
Image 2353
Satisfaction mark by Johan Palm 5 years ago
