Bluetooth enable G11 gateway
Evert-Jan 6 years ago in IQANdesign updated by Gustav Widén (System support) 6 years ago 2
I did set the G11 enable on false and also the Bluetooth enable on false, but still I can connect with IQANGO, and for example change the system ID. How can I disable the Bluetooth radio?
In IQANdesign, set Enabled to Yes, and use a channel to control Enable Bluetooth.
The default function of the G11 is to have the Blutooth on (that is why it works even when it is not added to the application), so to disable Bluetooth the system headmaster sends a command to it. But with the module disabled in IQANdesign, no configuration is sent to the G11.
