We have tried accessing a machine remotely and have the following message "no reply from IQANconnect server". is this a problem on Parker end?
Richard Ness 6 years ago in IQANconnect updated by Gustav Widén (System support) 6 years ago 1
We have tried accessing a machine remotely and have the following message "no reply from IQANconnect server". is this a problem on Parker end? We have tried 2 PC's and have the same message.
The IQANconnect server is up and running.
When you see this message in IQANdesign/IQANrun, a plausible explanation is that the firewall is blocking it.
I'd recommend to check with your IT-department if your firewall might be blocking HTTPS on port 443.
It happens that some organizations block this.
