Referencing a Transition
NEricson 6 years ago in IQANdesign • updated by Edward Polzin 6 years ago • 1
Is there a way to reference a transition in the FSM to block a channel?
Please see attached example (IQAN design 6.04) to see if this resolves your question.
In this example, toggling the digital input will change the states in the FSM.  Refer to the measure group, but you should be able to see each of the Transision x --> x IDC go high when a transition occurs.  Hope this helps.
Reference FSM Transition Example.idax
