Sorting Inputs and outputs in Iqan 6
Michael Carlyle 6 years ago in IQANdesign updated by Gustav Widén (System support) 6 years ago 1
Can we get the input letters shown on the Iqan module inputs and outputs and the ability to sort by them added back.  It is much easier to be able to just look at the module setup this way.
By sorting, do you mean having a view where the channels show at their original position in the block diagram, like it was in version 4 and earlier?
Or to have the occupied pins showing first as it is now, but with a sorting feature to list them based on letters, so that e.g. VIN-A comes before VIN-C?
You can sort the pin order (drag and drop the block diagram pin), but it is a manual operation that moves one block diagram pin at a time.
