Display Module pages to Touch Screen
Anastasia Xenaki 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 1
At the moment the display I have on the touch screen and the display I have created in the iQAN design are completely different.
I need to directly display the user interface pages to the touch screen.
How can I connect my project to the touch screen?
Thank you
You will need a licensed copy of IQANdesign to send the update to the IQAN-MD4.
The best method is to use Ethernet, as the file size is quite large.
For this, you will need an Ethernet cable, see:
https://www.parker.com/Literature/Electronic%20Controls%20Division/Literature%20files/IQAN_Accessories_Catalogue_MSG18-8319_UK.pdf
An alternative is to use a CAN adapter:
https://forum.iqan.se/en/knowledge-bases/2/articles/231-usb-to-can-interfaces
