IQAN Comment Tag
Anastasia Xenaki 6 years ago in IQANdesign • updated by A DOMS 4 years ago • 5
Is there a way to insert comment tags in the interface?
Hello.
You can add comments feild in the application feilds by right clicking.
You can also add comments to Qcode by typing //
Everything after that on the same line will be a comment.
Is it possible to add / remove the double "//" for many line of code ?
Often I put my code in comment to try something, after I want to remove it.
Is it possible to do it in one time ?
What if you copy paste the code into another text editor and removed the comments. Then you could paste it back without the comments.
It's a way to do that yes.
For exemple in VBA on Microsoft Excel, you can comment or uncomment several lines with these buttons :
No, the // is the only way to comment in Qcode and it only affects the rest of the line.
You can not abort the command to insert a comment in the middle of a line either.
