Input calibration Properties
Greg R 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 2
Would it be possible to make the input/Output calibration properties able to be pulled from existing channels? We currently have sensors whos inputs need to be recalibrated when changed out and we need to use memory channels or adjustable parameters to accomplish that. It would be nice to use the existing property values for this.
It should be possible to add input and output channels with calibrations to adjust groups.  Would that solve your issue?
If you get a settings file, you will be able to view all adjusted values offline.
What you could also do is to use IQANscript to make a script that read out individual adjust items or individual parameters from an adjust item (e.g. min calibration parameter on a Voltage input).
