Graphs and Variable Adjustment
chuck streb 5 years ago in IQANdesign • updated 5 years ago • 4
I would like to see graphs in IQANdesign while i adjust variables to optimize my control loops.
Is there an easy way to do this? without jumping between IQANrun and IQANDesign?
If I understand your question correctly you can just use a measure group and plot the variables you want to adjust. Just drag and drop the variables you want to see to the measure group.
i would like to be able to change variables and view a graph at same time ,,,
i cant find a way to do this in iqan
If you have an MD4 in the system, you could use IQANdesign or IQANrun for graphing, and make the adjustments from the MD4 menu. If your adjust groups are protected with a user level, connect with IQANrun and log in, and keep the IQANrun connection open to avoid being logged out.
unfortunately this isn't an easy setup. i am doing a lot of system calibration and need to change variables and record results to find the variables I need to use. this is a new system so there is a lot of data collecting to do. wish this could be simpler to do
