Event Counter Object List: Visual Bug? (6.06.10)
Fabian Lagerstedt 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 1
Experienced a visual bug on two out of three object lists when selecting an ECNT channel. Disappears when clicking on each bugged object list area.
Image 2735
Initially the object lists looks like this:
Image 2736
When clicking on the "Decreasing" area the visual bugged object C disappears.
Image 2737
When further marking the "Resetting" area the visual bugged objects B and C disappears.
Image 2738
The increasing area is not bugged in this example.
Satisfaction mark by Fabian Lagerstedt 5 years ago
It happened in 6.06.10 when you navigate from a channel without function and the function inspector is not pinned up.
Here are two other posts on this issue:
https://forum.iqan.se/en/communities/1/topics/2802-idc-shows-copy-of-activating-object-on-blocking-side
https://forum.iqan.se/en/communities/1/topics/2804-interactive-message-channel-math-object-appears-and-cannot-be-interacted-with
We released the IQANdesign 6.06.14 update earlier this week, this fixes the bug.
