DBC missing 32bit offset values when exporting complete CAN database
toby 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 3
So when I export my complete generic CAN database, by going to the Generic CAN module, selecting everything with ctrl A and then going File-->Export-->Export CAN Database, it will export the .dbc however it is missing every 32 bit offset parameter in any paged protocol Generic Frame ins, other than in the 0 page. This does not occur if I just select a single Generic Frame In channel and export it. Any help or potential work arounds would be appreciated. Thanks
What IQANdesign version are you using?
Do you have any GPIN (or JPIN) channels located at the same offset as your page mask?
Thanks for your reply. I'm using 6.06.14.7677. No I have my page mask set to 0xFF and my first GPIN has a bit offset of 8 bits and if I look at my bit table, there are no overlaps.
There was a problem with exporting GFIN channels with paged protocol. Fixed in 6.08
55269Problems exporting CAN database with paged protocol
Fixed.
