+4
Startup logo as adjust item
Marcel 5 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 8
Is it possible to make the startup logo adjustable? So as an adjust item for example? Some customers like their own logo as startup screen, I don't want different software versions only for the startup logo.
Thanks!
Marcel
What some designers do is they select a neutral startup image, and then add display pages that show on startup to display the specific machine brand logo.
If the startup log could be controlled by a parameter, that would simplify these designs.
I can update the topic and change it from question to feature idea if you like?
I would like that yes!
Thanks!
I came here to say the same thing. We use a different image depending on where in the world the machine ships to. It would be nice to select (in the menu) which image is used.
Planned
A method for supporting multiple startup logos in one project file is planned for next version.
(it won't be adjustable from the MD4 though)
With IQANdesign 7 variant projects, the startup logo can be a variant controlled by an option group.
