+3
Option to show PIN code
Argy 5 years ago in IQANdesign updated by Gustav Widén (System support) 5 years ago 3
Using 6.06 I have that when I try to enter a PIN Code the machine masks the number selected with astrisck. Is there anyway to change this so the number is not masked?
Some people have shaky fingers and they have difficulty entering the correct code number.
Argy, I took the liberty of converting your topic comment from this post to an separate post.
Currently there is no option to show the PIN code.
A question, is the problem in an application that shows the spinner or the keypad?
The problem is with the keypad.
Maybe to option to view it and edit it after it has been entered would help.
Maybe set the masking as an option would help?
Maybe adding an "Eye" icon push button that momentarily reveals the numbers selected, as used in other online password entry systems, would help.
