Rate of change function. How to limit the rate of change of output.
Raj 5 years ago in IQANdesign • updated by Edward Polzin 5 years ago • 1
Hello All,
We are implementing an application which requires limiting the rate of change of output. Is there any solution available in IQAN design ? The parameter is integer.
Appreciate your help
Thanks,
Raj
There are start/ stop time settings in the current output properties.
There is also a slope channel that can be configured to do this also.
