Freeze Version 6.06.14.7677
jan 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 5
Good afternoon,
Just to your information:
Error occured:
During resetting gradient value, I accidentally reset wrong value to 0 (Position [%] Stop 1, should have been Direction [°]) , was not accepted by IQAN Design software, should be minimum value 0,1, at that time the software freezes completely, could not approach any function in function bar (although I was able to start a new project) , had to restart desktop to reset freezed application.  Vastlopen Design.jpg
The printscreen shows a popup is up, I assume you must have tried pressing the OK button?
Hello Gustav,
All buttons inside the complete IQAN Design Pop-up frame were frozen, only way to get the frame vanished was to shut the desktop down and make a restart
I had this same problem today.
Here are the steps to reproduce:
* Open a finite state machine and edit the inputs of one of the transitions
* Type any text into the input box but do not click a channel
* Select one of the display pages in the left navigator
Now the popup "Property error" shows up and it is impossible to close without killing IQANdesign.
Since the display page is now active it is not possible to change the input to an accepted value.
Started
Thank you Pierre, there will be a fix for this in 6.08
