symbol button control
BOYER 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 1
Hello, I would like to keep a Symbol Butoon Control switch on when I push on it twice.
My problem is on the second push. At this time the button switch off and I want to keep it switch on.
The reset is done by a push on a second button. Thanks.
The easiest solution would be if you could have the button toggling instead of latching it on a double click.
To make it toggle, just set this property on the VDIN channel.
If you need a button that latch on a double click, you could build it up with a transparent custom button for the input, a little application logic for the timer and a lamp control for the visual indication.
