Inserting a parameter in the lookup table
NEricson 5 years ago in IQANdesign • updated by Mike G 5 years ago • 1
I would like to be able to insert a parameter into the column of a lookup table. Is there a work around?
Image 2895
Have you considered using the "Multi Vector Object" in a Math Channel?
It functions very similar to a look up table, but the "table" values can be from any channel with integer or real numbers.
