55093 NOT a Bug, a Feature
Huddig Daniel 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 2
Function is used for different machine configurations, please make check "Warning" not Error!
Satisfaction mark by Huddig Daniel 5 years ago
Just to clarify for other readers, this about the check for duplicate address on expansion modules.
55093Missing check for"ambiguous module address" for expansion units enabled with a channel
Check added.
It was not necessary to have the check as an error for the classic expansion modules, like XC21.
Project check updated in 6.08 to only give error for XC4x modules.
56761Expansion module enable revisited
Using the same module type/address for modules on an expansion bus now triggers a warning instead of an error if the modules are enabled by channel. For modules on a high-speed expansion bus an error will always be triggered if the same type/address is detected for modules on the same bus.
