Set Date/Time from IQANDesign Code
GHolford 5 years ago in IQANdesign • updated 5 years ago • 2
It would be nice if we could set the date/time automatically through the IQANDesign application. We have a way of getting the current date/time from an external module, there's just no way as far as I know to force the application to sync with that time.
So I imagine it could look something like this
Image 2940
It is possible to sync time over J1939 if the option is enabled in the system layout.
Okay, this works for our setup. It looks like you can only set the date if it is after the current system time, not before?
